Setting ones and zeros bit by bit to a 16 bit unsigned int?
I am trying to write data to DACs to control the voltages applied to 64 (8x8 grid) different pins on a piece of hardware. I currently have an 8x8 string array of the bit strings (ones and zeros) necessary to be written and control the specific DAC. Is there any way I can convert this 8x8 array of ones and zeros stored as a string into an 16 bit unsigned integer 8x8 array of those same ones and zeros? I am having an issue where I end up losing the leading zeros from the string when converting to unsigned int.
Thanks!
(1,587 Views)
Accepted by topic author lmcohen2
Show a VI that demonstrates what you are talking about.
An integer can't lose leading zeroes.  A 16-bit integer will have 16 binary digits.  Perhaps you don't see the leading zeroes because you are displaying the integer in an indicator as a binary display format that isn't showing them.  You can change the display format to be binary, have 16 digits padded with leading zeroes.
(1,583 Views)
That solved my problem, thanks!
(1,568 Views)
