08-31-2015 06:00 PM
I want to display a 16-bit image with the range I specified for the ROI selection. Is there a way to use the IMAQ WindDisplayMapping.vi with IMAQ ConstructROI.vi to display with the range I want? I tried to set the same window number for the two subVIs but that does not work...see attached picture. Any suggestion or help is appreciated!
09-01-2015 10:51 AM
When you say range, do you mean it in terms of pixel depth, or are you trying to display only the selected region of an image based on the ROI?
09-01-2015 11:12 AM
09-03-2015 09:53 AM
I think there's a confusion about how these functions work. Looking in to the documentation for this function it seems that "Given Range" would select the pixel values between 500 and 3000 to be scaled, not scale all values to between 500 and 3000. We talked about it here as to what the best way to go about this would be, and the only thing we came up with was to create a new image.
