Set a condition after some elapsed time
Hi, I would like to trigger a signal if a bit is 1 for 3 sec. Could you please help me to do it in LabVIEW. So 2 conditions should met
1- the input boolean value is True
2- it is continuously YTrue for 3 sec
Then if both are true set condition terminal of a case structure to be True, otherwise the case structure condition terminal is False
(3,089 Views)
You can modify this for your application.
(3,080 Views)
Hi SumTomWong,
many thanks for your help. It can do the job but I would also like to reset the timer to 0 when both condtions are true. I don't know how can I reset the timer using your method. This is the reason that I thought to use Elapsed Time function
(3,074 Views)
You can try this.
(3,070 Views)
I am also unclear about your requirements, whether you want to reset the output too. This example show how to reset the output every 3 seconds when the input is true. The top is an example without using the elapsed timer and the bottom is an example using the elapsed timer.
(3,059 Views)
