Set Variables to sub VI from main VI
Made multiple attempts to configure sub VI to call Main VI but unable to configure user inputs to change settings. Need help setting up sub VI to call from Main VI that can vary with user inputs? Please refer to attach VI's, current VI calls sub VI but unable to change USER inputs or change variable.
(829 Views)
I would look but I'm on LV21. Maybe save the VIs for previous versions of LabVIEW.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(807 Views)
Accepted by topic author Manny904
A sub should never call the main. If you want it free running (as now) you'll send information through Events, Queues or possibly a Global variable.
Qestit Systems
Certified-LabVIEW-Developer
(761 Views)
What I would like to achieve is having an option to choose between infuse and withdraw to also change position of valve? how do I go about achieving this?
(751 Views)
I figured it out by using case structure sequence as you mention. Thank you!!!
(731 Views)
Nobody here mentioned any "case structure sequence". I don't even know what that means, but it is certainly not something to communicate between VIs. 😄
(727 Views)
