Serial port is still open even after closing it explicitly
I need to close a VI that is using a COM port and use the same port through some other program. But for some reason even after I stop the VI where I explicitly close the com port, I can not still use the hypterterminal to connect to the port. It says port is being used by some other program.  What can be the reason? Any thought ?
Ananda
(2,581 Views)
Is the VISA close the last action you perform on the VISA reference?
If not, then your port will probably be opened again, so make sure it's the last one.
Also, I seem to remember reading something about some bug where VISA close wouldn't properly close the port. I would suggest you try searching for it and also make sure you have an updated version of VISA.
___________________
Try to take over the world!
(2,570 Views)
