Sensirion EM1NH
Hallo everybody,
i have a Sensirion EM1NH4R0V_1A Sensor und want to be able to control it and use its results using the LabView software. The Sensor is connected to the PC via the RS232 . How would this be possible?
I am a really new user of this Software, so any help will make be sure gratefull!
(2,267 Views)
From LV, goto Help > Find Examples, then open the Serial folder.  There are a few basic example to get you started on serial communication.  From there, you will likely need to read the sensor manual to figure out what commands to send it and read the info back.
Make sure your communication settings (COM port, baud rate, parity) are correct, or you will be pulling your hair out before you get anywhere.
(2,258 Views)
There are several examples in the example-library- try them!
Are all the necessary drivers installed?
-> NI-serial
-> NI-visa
For more information:
http://digital.ni.com/public.nsf/websearch/E22DA85E97818DE78625678C0069BFC9?OpenDocument
http://zone.ni.com/devzone/cda/tut/p/id/8402
To test your RS-232 communication interface:
http://zone.ni.com/devzone/cda/epd/p/id/4318
(2,248 Views)
Vielen Dank für ihre nette Hilfe!
(2,228 Views)
