Sending commands to RSPD 3303X-E power supply
Hi All,
I have a RSPD 3303X-E power supply that I would like to control through labview. I keep getting an error message as follows: Error-1073807343 occured at VISA Open in file-name.vi
Possible reason(s):
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
I am able to send the ID query command using NI MAX but cannot achieve the same in LabVIEW using the NI-VISA library.
I have included a copy of the file for your reference. I will be grateful if you can help me. Perhaps can you provide LabVIEW examples for sending commands to RSPD 3303X-E.
Thank you in advance.
(426 Views)
Accepted by topic author Mohkey
(377 Views)
Thank you for the link. I managed to find the specific driver for RSPD 3303X-E in NI library and it works fine now. One can find it under the manufacturing name Siglent Technologies.
Thanks again.
Mohammad
(337 Views)
Also wanted to share the file in case someone needs it 😊
(336 Views)
