Sending a signal to 1 of 2 different pins on a DAQ device
I am trying to make a VI that simply sends a digital signal to 1 of 2 pins on my DAQ device. Is there an easier way to differenciate between the two pins then using two different virtual channels?
Message 1 of 8
(2,168 Views)
Try the attached.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 8
(2,157 Views)
Do you realize that your "0" case can never execute? An important point to take from Adnan's example is that the VI doesn't continuously apply a signal to a line.
Richard
Message 3 of 8
(2,154 Views)
sorry I have LabVIEW 8.6, I cannot see your VI
Message 4 of 8
(2,147 Views)
Here you go in 8.6. Also, please note to read two lines you will have something like this in the channel constant: Dev1/port0/line0:1
Adnan Zafar
Message 5 of 8
(2,132 Views)
what do you mean by "VI doesn't continuously apply a signal to a line".
and there is no event to handle stop case ......
please explain
thanks
Message 6 of 8
(2,126 Views)
Yes, an extra event would be needed to handle the stop case. Sorry I built it up really quick.
Alok, there is a difference between using an event structure and simply running a while loop. That should help you understand why he wrote that.
Adnan Zafar
Message 7 of 8
(2,117 Views)
thanks for reply Adnan,
i know the difference between simply running a while loop and using event structure ( though i am pretty new to labview),
ok i have to admit that while writing this post i think i got the point.
Thanks again...................
Message 8 of 8
(2,113 Views)
