Sending Values to a front panel cluster
Hello
I am fairly new to LabVIEW and struggling to understand how I send a numeric value from one of my sub vi’s to a numeric indicator in a cluster on the main vi’s front panel? I have been able to send control values to the vi using the method in the snippet.
Unfortunately I cannot share my vi so have simulated the layout.
 Thank-you in advance.
Mick
(567 Views)
In general you shouldn't use the control refs to send data like that, but connect the control/indicators to the VI's connector pane and send the data.
That being said, you need to read the cluster first so you can use a Bundle with name to change a specific part and write it back.
/Y
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
(559 Views)
Hi Yamaeda
Thank for your reply, my original vi did use the connector pane as you described but the vi was becoming cluttered so i ended up changing it for the present, I apologize for my lack of understanding put could you show me an example of your second suggestion.
Mick
(541 Views)
Accepted by Iberian2000
Bundle by name.
(537 Views)
Brilliant !
that worked a treat thank-you.
Cheers
Mick
(530 Views)
