Send signal from labview to simulink model.
Hello all
I want to send a digital signal which will be high when a start button is pressed and zero when stop button is pressed from labview to simulink model. Is there any simple way to do this other than sending packets through UDP, TCP/IP?
Thank you.
(3,079 Views)
Hi!
Are you running the model using the Simulation Interface Toolkit?
(3,070 Views)
Hi Marco
I don't have simulation interface toolkit. Is it required?
(3,068 Views)
Give a look here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209048
With SIT you can execute your model within Labview and can iteract easily with it, for istance exchanging I/O, setting parameters etc.
Marco
(3,064 Views)
Thank you for the advice. I'll definitely look into it.
(3,061 Views)
