05-06-2020 06:32 PM
I'm trying to send a text message to my mobile phone using my GMAIL STMP server and my carrier (AT&T)'s SMS Gateway. When I run this VI, I get:
Solved! Go to Solution.
05-06-2020 06:34 PM
I should add I enabled IMAP and POP for my gmail account in case that was necessary.
05-06-2020 06:42 PM
Wow nevermind I figured out the problem. I had to enable less secure apps for my gmail account. Then it worked!
04-09-2021 12:32 PM
I am have difficulty sending email via LabView code. I am getting the same error you reported, but I do not understand what settings you changed in gmail to correct the problem.
