Select specific channels to display for indicators (DAQ)
StathPol ha scritto:
so for example, if a sensor (3) breaks, can't i just deactivate the boolean and work? Do I need to re-modify the vi again?
Yes, VI doesn't require to be modified for this.
Message 11 of 15
(1,610 Views)
In your current setup, you cannot "remove" one signal except the last one without "moving the other signals to different graphs".
Have you found the option to disable plots in the graph as i recommended?
Norbert
Norbert
Expert: Geometry
Message 12 of 15
(1,566 Views)
Do you mean the option in the visible items (Plot Legend) or to incorporate a property node?
https://forums.ni.com/ni/attachments/ni/170/698458/1/plotvisibility.PNG
In the plot Legend, I should see a tick box.
Message 13 of 15
(1,534 Views)
Accepted by StathPol
You can modify that setting using property nodes. But you can also show the checkbox and let the user decide (remove the other boolean buttons in that case).
It is your decision.
However, the DAQmx task always reads out all channels, just display removes "invalid" plots....
Norbert
Norbert
Expert: Geometry
Message 14 of 15
(1,527 Views)
Thanks both of you guys.
Message 15 of 15
(1,520 Views)
