Searching from excel file
@sam67 wrote:
@GerdW wrote:
Hi sam,
you didn't upload VI Gerd..
No, intentionally.
Come on: you see my example!
It's just 3 functions, two of them IndexArray and one Search1DArray. And you got an explanation, so you should be able to replicate the example on your own!
(By wiring yourself you learn much better than by just taking code from someone else. :D)
hahhahaha yes got it man btw thanks allot. see you in next problem 🙂
but i appreciate that if you send me this example code for example and i will save it for future
Message 21 of 96
(624 Views)
It return only first or last column. could you please check it again
Message 22 of 96
(611 Views)
Hi sam,
I don't see my example code in your VI: maybe that's the problem…
Again:
  1. Index the first row
  2. Search your desired header string
  3. Index the column where you found the header string
Did I suggested to use AutoCleanup before? PLEASE use it before uploading your VI (and save the VI after using it)!
using LV2020 on Win8.1+cRIO
Message 23 of 96
(608 Views)
@GerdW wrote:
Hi sam,
Again:
No, now its return only zero, i dont what i did wrong in this code. Please see the code and tell me if you can. Thanks
Message 24 of 96
(597 Views)
Hi Sam,
still not my example code in your VI. I don't see where you index the first row or the column you want…
What's the point in replacing an array element by your string and then search that string in this array?
Message 25 of 96
(590 Views)
@GerdW   wrote:
Hi Sam,
still not my example code in your VI. I do not see where you index the first row or column you want ...
What's the point in replacing an array element by your string and then the string in this array?
Thats the file in which I want to search the column D just and store the column D value in another array.
According to the present invention, there is a need for a method that can be used to generate a list of indexes. Maybe i am wrong due to missunderstanding but if i am wrong then please correct me. Thanks
Message 26 of 96
(580 Views)
sorry i forget to upload xls file. this file in .xls extension but here .xls extension is not uploaded thats why i converted it into text file
Message 27 of 96
(577 Views)
Accepted by topic author sam67
Hi sam,
why don't you just apply my example:
It consists of just 3 functions!
You fail in wiring theses 3 functions and in using AutoCleanup as well…
(From this experience I recommend to take the beginner courses offered for free in the Training section in the header of this LabVIEW board!)
Message 28 of 96
(566 Views)
@GerdW wrote:
Hi sam,
Thanks allot gerd.
Message 29 of 96
(559 Views)
@altenbach wrote:
e.carano wrote:
I'm a beginner in using LabVIEW with datafile.
If you want code, you need to tell us your LabVIEW version.
If you have a recent version, you can use a conditional tunnel to simplify the code even more. (see attached 2014 version).
hi, i applied as it as you display in your picture but i didn't get the results. i am beginner in labview so if i could something wrong then please correct me. Thanks
please find the attached file
Message 30 of 96
(534 Views)
