12-04-2019 09:18 AM
I have a list of many user to store information. I put them into the array string and use the Ring to be able to choose which user i want. But I had a hard time with too many users, which made it very difficult to access. Is there a way to search by the elements in the string and give the fastest results?
Thank.
12-04-2019 09:39 AM
There is no built-in search capability of a ring control.
You could add the function to the owning VI, or design an XControl that has that capability.
12-04-2019 10:03 AM
So sad. My current level cannot add functionality to VI ownership or XControl design. Currently I am using the vertical bar to search for users. My user list is getting bigger and bigger, I can't use this method forever. Can you guide me to do the above 2 ways?
12-04-2019 10:08 AM
Check out Darren's nugget on building the quick drop functionality. Maybe something here will help you. tst also posted a link to his code that does autocomplete.
12-08-2019 08:09 AM
thank you, i used combo box in string function.
12-08-2019 08:44 AM - edited 12-08-2019 08:44 AM
12-08-2019 08:51 AM
This CLA Summit presentation (around 5 minutes) might help you - it's not exactly what you want (I don't think) but it's pretty darn close from what I understand:
12-08-2019 10:24 AM
Thank you for comment. Darren's way is great but I need to use it when running vi, so I used the combo box, it fits my program very well and I found it to be similar to ring and enum but it is searchable
