06-27-2012 07:36 AM
Hi All,
I have worked in normal SCADA Systems. Assume that in a Project we have screens like, Plant Over View, Trend, Alarms etc... By configuring buttons I can Navigate from one screen to other.
I'm new to Labview, with my understanding of labview, its screens are saved as ".vi" (ie; PlantOverView.vi, Trend.vi, Alarms.vi etc..) . So I want to know how can I navigate from one screen (or vi) to other from the Front Panel?
If you have examples plz attach...
06-27-2012 07:41 AM
I'm sorry, but I don't understand what you are asking about at all. What do you mean by "navigating" from one screen to another from the front panel? There are no "screens" in LabVIEW.
06-27-2012 07:50 AM
Ok... I this I miss the architecture of Labview, but I want to learn it.
Assume that, I have lot of animation, Graphs, real time values to show. It is not possible to include all this in a single VI. So what you do is split the requirements, like animation in one VI then Graphs in other VI, right?
So when I'm running animation VI, how can I open Graphs VI?
Hope you understand?
06-27-2012 07:56 AM
You can use a tab control. That would be the easiest way to do it. Look into a tab control. You can a property node to change the tab page which makes it seem like different windows.
06-27-2012 07:59 AM
You can open separate VIs by using the VI server. Alternatively you can have multiple parallel loops running in a main VI that has these child VIs in each of the loops. Personally, I think the dynamic lanuch of the VIs is a better approach. Search these forums, as this kind of architecture has been discussed many times before, and examples have been posted.
06-27-2012 08:01 AM
That can be accomplished using tab controls, or sub-VIs, or sub-panels.
The zip I included in post # 18 of this thread has an example that demonstrates how to realize "Docking" in LV.
These images demonstrate Docking in an application.
This album has more images of that application.
Yes that application ran on a machine with 2 very large displays.
Ben
06-27-2012 08:17 AM
You can stretch one vi over several monitors, if need be, but to answer your exact question i think you can use the Focus-property on another vi (through it's ref) to handle tab-control between vi's.
/Y
06-28-2012 07:09 AM
Thanks each one of you, all of your suggestions were new knowledge for me....
Hey I found a "Jump Button" under Navigation Buttons, which really served my need..........![]()
03-15-2018 06:30 AM
I am new in LAB View. But i have good knowledge in SCADA System. So i want to make one of project same as scada in LAB View. But i face many problem.
Can you please share this thing, because i also want nevigation in VI.
I found jump button. But how it's work i don't know.
03-15-2018 07:42 AM - edited 03-15-2018 08:01 AM
@NitinB wrote:I am new in LAB View. But i have good knowledge in SCADA System. So i want to make one of project same as scada in LAB View. But i face many problem.
Welkom. Start with some (free) courses.
Lesson 1. It's LabVIEW, not LAB View.
@NitinB wrote:Can you please share this thing, because i also want nevigation in VI.
What thing? Who's thing? Different things where mentioned. Be specific.
@NitinB wrote:I found jump button. But how it's work i don't know.
The jump button won't fix anything, nor will it help you in any way to navigate. It's just a button with an arrow, apparently something OP was looking for.
