06-24-2009 03:27 AM - edited 06-24-2009 03:27 AM
Hi muks,
delete these wires. You get this because in LV80 the call library function node hasn't an error connector. I created these vi's with a higher version and saved it for previous use. So you have to clean the broken wires.
Mike
06-24-2009 03:30 AM
06-24-2009 04:01 AM
Hi muks,
sorry for this. I'll check it in the evening, and if possible i send you a running LV71 or 80 version.
Mike
06-24-2009 04:53 AM
Hi mike,
Solved the problem. The write to bmp was creating the crash. So I replaced it with getclipboard image. In addition I changed a couple of things in vi properties and It is working perfectly fine. Thanx a lot for the help mike.
