Saving value only once when condition is true
I have problems when i am trying to save value to file. How i can just save value to file(spreadsheet etc.) when condition is true and only once.
Program should continue normally, so it must happen in background.
(3,052 Views)
Depends on whether you are initiating the file save with a front panel boolean, or programatically. If it is with a front panel boolean, just have it enable a case structure with the save (either to file, or spreadsheet) in the true case. Also in this case, put a local variable from the boolean, tied to a false constant to reset the boolean.
IF you are waiting for a programatic true condition, then use a short time one-shot between the programatic true and the condition terminal of the loop. It sometimes helps to put a short time delay in the true condition case as well. I use a one-shot with a 10 ms. output pulse, and put a 10 ms time delay in the true case. That way, you are assured that you don't save twice for one false-to-true transition of the programatic boolean.
Good luck
Dave
(3,047 Views)
