Saving typedef value in .ini file
I need to SAVE Position 2, button size, Numeric text size and Position values in an .ini file and later READ that file to display the elements in the same exact position. Can anyone help?
(460 Views)
Hi tan,
Help to solve which problem?
  • You already can read all those values, now you just need to save them to a file.
  • You already know you want to use a Config (aka .ini) file, so you just need to use the Config file functions in the file palette…
  • You already know you want to save and to read those values, so you just need to create two VIs to handle each task…
Where exactly is the problem you need our help for?
(444 Views)
solved. Thanks for the help!
(408 Views)
