09-25-2014 11:06 AM
Hi!
This is probably an easy problem to fix but I can't figure it out. I have 2 loop that runs in parallel and write to measurement file is working for the analog waveforms. But when I trying to save the temperature array only one value is written to the file. The analog waveforms collect values much faster than the temperature so I want to just save the latest array value from each channel when 1 value from the analog waveforms is saved.
09-25-2014 11:37 AM
I would recommend making another loop for saving your data. You can use a queue to pass the data to that loop. Just store the latest value of your analog signals in a shift register. When you get a temperature reading, you append those readings to the array of analog signals and write the data to the file.
09-25-2014 12:06 PM
Thanks for a quick reply. Sorry but I don't understand you completely and I have been told that the write to measurement file should be in that loop. What I read from your suggestion is that the analog signals that are aquired at 20kHz wait for a 14hz temperature data to be aquired in the queue. In your suggestion if I can get it to work will I then get the same amount of temperature data as analog data saved to the file?
09-25-2014 12:25 PM
Isn't that what you asked for? If not, the clarify what it is you want to do.
You can use another loop quite easily. Just look at the Producer/Consumer.
