Saving polymorphic vi as single file
Is there a way to save polymorphic VIs as single files? As far as I understood, the polimprphic VI is somehow a list of "links" to the different instances. Is there a way to include the instances on the "main" vi, and maybe access them via the polymorphic VI window?
Message 1 of 13
(4,641 Views)
Would the LLB be useful?
Can you put all the VIs' instances in an LLB
Best Regards
Hu Yu
Message 2 of 13
(4,639 Views)
Hi nihuyu,
thanks for replying. That should work, but it's not exactly the same...
Is there a way to do so without an LLB?
Message 3 of 13
(4,634 Views)
Hi xdaf,
well, each instance of a polymorphic VI is a VI - you can save them as individual file or collect them in a LLB. No other choices.
Why do you want to have them in one file?
Message 4 of 13
(4,630 Views)
Well, it's just to avoid having a long list of files in my folder...
In fact, that's exactly what an LLB is intended to do, but the LLB should be more a collection of different VIs related to the same topic (for example, the drivers for an instrument), and not a collection of VIs doing exactly the same thing on different data types.
Nevertheless, I'm going to implement nihuyu's solution.
Thanks to both.
Message Edited by xdaf on 01-27-2010 11:34 AM
Message 5 of 13
(4,614 Views)
Hi xdaf,
isn't "a collection of different VIs related to the same topic" a perfect description for your polymorphic VI collection?
Message 6 of 13
(4,610 Views)
Hi Gerdw,
I wasn't clear, sorry: I'm not speaking about a collection of polymorphic VIs, but about a single polymorphic VI (and his instances).
The problem is: you can build an LLB and obtain a single file, but if you save the LLB on your user.lib folder, and browse its contents, all polymorphic instances will be listed.
Isn't it a nonsense? Shouldn't only the "main" VI be displayed?
Alternatively, is there a way to hide the instances while browsing the contents of the LLB?
Message 7 of 13
(4,585 Views)
Hi xdaf,
I usually solve this issue by this procedure:
- I have my user.lib files in a different folder (in my local user path) and only edit the palette to include the VIs I need (This way it's much easier to backup all of my VIs.)
- I usually only put the polymorphic VI into the user.lib. All the single instances are located in a different folder and thus not seen in the user palette.
Disadvantage of this scheme:
When I install a new LV version I have to setup my user palette content again. Well, it's just 5 folders in the user palette... Smiley Wink
Message Edited by GerdW on 01-28-2010 03:07 PM
Message 8 of 13
(4,581 Views)
Understood... but what in case you want to redistribute your VI (for example to your colleagues, or a wider community)?
Your proposed solution works, but is a workaround...
Thanks for the suggestion anyway.
Message 9 of 13
(4,573 Views)
Hi xdaf,
there's only one collegue to share the user.lib ( Smiley Wink or Smiley Sad ?), so no problem here (it's a one-time operation).
Otherwise I only hand out executables...
Message 10 of 13
(4,566 Views)
