Saving different jpeg file for continuous reading of height image
Hi, I am facing trouble with saving the jpeg file of the data continuously. I have attached my VI. In this I am able to save the jpeg file but when the graph gets complete the new graph starts saving in the save jpeg file by overwriting the previous one. I am getting data at a very high speed. So I want to save all the graphs in different jpeg file in the same folder.
I am new to lab view so if you can help me from basics or either by changing my VI files will be highly appreciated.
Thank you
(173 Views)
Hi ish,
what's the problem to use a unique filename for each JPG file?
CLAD expired, using LV2011SP1 + LV2017 (+LV2019 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
(159 Views)
Highlighted
Hi GerdW,
Thanks for such a quick response. Can you let me know how to do that as I can see in the write jpeg file just to give one file name that it saves.
(153 Views)
Just create a different filename for each file...
(There is a full palette of file functions!)
(148 Views)
It overwrites your old data since they are having the same file name. If you can give a unique filename for each image, that would solve your problem. For example, append the timestamp to the filename.
(102 Views)
Here's a simple example.
Make sure to read the comment box!
You might also want to consider the Create File with Incrementing Suffix VI.
GCentral
(89 Views)
