Saving an Agilent N1996A waveform trace to graphics/Excel files
I am new to LabView.  I need to create a VI that will save an Agilent N1996A (CSA) waveform trace to a graphics file (PNG, BMP). The user will enter a filename through the front panel.  The Functions palette has a CSA ReadTrace.VI that sends the data to a waveform trace but I do not know what other objects or wires to use to save the data to a file specified in the front panel.
Additionally we need to export the X and Y arrays from the trace to an Excel file, which will also be given by the user through the front panel.
Thanks!
Nina
(3,182 Views)
You can use the Get Image method with the appropriate write function on the Graphics & Sound>Graphics Format palette.
The Write to Spreadsheet File is just one of the File I/O functions you can use.
(3,157 Views)
Dennis,
Thanks for your reply!  I also found a document on ni.com called "Exporting a Waveform Graph or Chart from LabView to a File" which reinforced just what you wrote.
Nina
(3,138 Views)
