05-14-2020 11:01 AM
Guys any idea to add all these function into my vi implementation and improvise them.
05-14-2020 12:32 PM - edited 05-14-2020 12:33 PM
05-16-2020 07:37 AM
yes i found the tools
05-22-2020 05:49 AM
guys how to save the 3 indicators (Missed, False hits, Actual Skips), including the participant's name into a text file in LabVIEW and
05-22-2020 06:47 AM - edited 05-22-2020 06:47 AM
Check out the "File I/O" palette. It has all the necessary tools to save data to a file. If You want LabVIEW to send the E-Mail for You, You will probably want to use some of the connectivity tools - depending on what exactly You want to do on what kind of system, which I am unable to guess.
05-22-2020 06:58 AM - edited 05-22-2020 06:59 AM
To save the data into a file, use the Vis in the I/O file palette. Open file, write text file, close file. You will need to format into string (a vi as this name in the string palette) your integers.
Then to send an email, use the palette SMTP in Data Communication>Protocols>SMTP email. Don't use the express VI as you can't add attachements. Use Open handle, Set recipients, Set message, Set attachements, Send.
Yddet
PS: LLindenbauer has been faster than me
05-22-2020 07:05 AM
hi regarding the smtp email i have created this vi but would like change to attach file instead. Anyone can help?
05-22-2020 02:20 PM - edited 05-22-2020 02:34 PM
Your question has already been answered. Use "set attachments" and the other tools in the SMTP palette. See also the second part (2013+) here.
