Save bin file over 4GB limit
Hi, I allocated buffer to save array data over 4GB and I want to save array by bin file.
I used write to bin file and it has limit 4GB, so I can't save whole my data.
Can I save bin file over 4GB in labview?
I use Labview 2015.
Thanks.
(3,238 Views)
more interesting than your labview version would be the bitness of your labview version.
could you not split files after a certain size (e.g. start a new file)?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,229 Views)
File sizes should not be limited. The internal array size does have limits.
What errors do you get?
(3,192 Views)
Not likely.  Definitely not with LabVIEW 32-bit.  You might be able to have it all with 64-bit LabVIEW and a 64-bit OS.
Generally if you want to save a file that large you log to the file as the data is coming in.  That saves A LOT of memory.  The file size is limited by an I64, so you should not have any issues there.
(3,161 Views)
I agree.
While the Read/Write spreadsheet file functions are limited to an I32 byte offset (that should be fixed ) the binary files should permit files large than 4 GB.
I am certain files over 4 GB can be read, but unfortunately, I deleted any temp files that I created that large so I have to trust my memory I have written files over 4GB.
Ben
(3,152 Views)
