Save FFT magnitude data
In my lab, I use .dat file form.
I want to save FFT Magnitude data with using 'Write Delimited Spreadsheet.vi' so I have to change cluster(3 elements) data to 2D array data.
Is there anything good to get 2D array data?
(1,903 Views)
Accepted by topic author Esther97
The FFT cluster consists of a f0 (starting frequency, probably always zero) a dF (distance delta Frequency) and a 1-D array of the frequency bins.  Use an Unbundle by Name rather than that ordinary unbundle and you'll see.  It is very similar to the Waveform datatype.
I assume by 2D array you mean a n array with a column of frequencies, and a column of amplitudes corresponding to each frequency.  Just use the f0, dF, and size of the 1-D array to build an array of frequency values with a ramp function, and build that onto the 1D array!
(1,867 Views)
