Save Array data and use it in a VI: it's possible?
See this figure:
1) I desire to save an array with ONLY same data that are taken only if there is a particular condition like the figure (Array3). I have done this, but doesn't save array, but only the last number. Can You do this VI to save an array when the condition of CASE LOOP it's true?
2) Il the right part of VI I desire save an array (better MAtrix Array), but I desire only an array of 30 element. After 30 elements I desire to start again from index 0. Can I do this? And after I desire to show in control panel the data of particular index (for example the 3 value of the same index of the maximun of the second column). Can I do this?
3) To finish I desire save array of 30 elements in an excel file.
Can You repeat a VI in LW8 for me please with this corrections? Thanks.
Message Edited by Michelle1892773 on 02-23-2010 05:00 PM
Message 1 of 10
(3,916 Views)
For array three try making the build array block so it has 2 inputs, put the data you want to add into the second input, and put the output of the block as feedback into the first input.
Message 2 of 10
(3,897 Views)
can you do whit features of question 1, 2 and 3? Maybe ut's simple to understand.
Message 3 of 10
(3,895 Views)
hope this answers all the 3 questions.
Regards
Guru (CLA)
Message 4 of 10
(3,868 Views)
Can You post your VI for LW8? Thanks.
Message 5 of 10
(3,858 Views)
Can You post your VI for LWV8?
Regards
Guru (CLA)
Message 6 of 10
(3,856 Views)
Guru but if I desire to save data in array, It's necessary to put an array indicator in front panel and after hide it? Or it's possibile to create a array directly in block diagram that I don't use in front panel but only in block diagram?
Thanks for VI.
Message 7 of 10
(3,853 Views)
If you want to "present" (or show) the data in the Front panel then you must create a control/indicator for that..
If you dont want to show ,why you want them in the block diagram (as well in frontpanel)?
Regards
Guru (CLA)
Message 8 of 10
(3,848 Views)
Like algoritmical variable used byt he program, but not important to see.
Message 9 of 10
(3,842 Views)
In LabVIEW that "variable used byt he program, but not important to see" is called a wire.  Smiley Wink
Play nice Michelle
"Should be" isn't "Is" -Jay
Message 10 of 10
(3,802 Views)
