Same scale for X and Y on XYGraph
I have an XYGraph which is fed with a double array of x and y coordinates. Normally, it's convenient that LabVIEW automatically adjusts the x and y scale to the appropriate size. But in my case, I'd like to have scaling in x and y direction with the same value.
I browsed through the options for XYGraph, but I did not find an idea. How can I do this?
(2,894 Views)
Hi mibeer,
you can set the scales on your own using property nodes - after you switched off autoscaling...
(2,893 Views)
Thanks for the answer.
But unfortunately, I do not see any property on XYGraph to turn off autoscaling. I can select a large number of properties in the property node, but I do not see autoscale anywhere, also not in any sub-menu. Where can I find it? How can I do it?
(2,858 Views)
Hi mibeer,
I do see them - just by reading the help...
(2,856 Views)
