10-24-2011 06:42 AM
I am planning to run my set-up overnight and during the weekends.
Labview is controlling the liquid level in my set-up. However, if Labview crashes at the moment the the filling system is on than the filling will continue forever (and the vessel will flood which is dangerous).
Can anybody tell me how can I solve this? I want my set-up to automatically shut down after a labview crash (so all valves needs to be closed)
Thanks for helping
Best regards
Elly Hoekstra
10-24-2011 07:14 AM
The only way you can take care of this is to understand what sort of crash will happen and make sure you have implemented a good error handling mechanism. So, when you get an error, the program should go into an error state (or something similar) and make sure you set the hardware and software to shut down smoothly.
Do you know why LabVIEW might crash?
10-24-2011 07:28 AM
The program did not crash till so far.
But we do not take want to take the risk.
Unfortunately I did not program a error handling system in my vi
I was thinking about the following solution, but I do not know if this is possible and suitable hardware exist for this
*) Write an additional loop in the program which is sending subsequently 0 and 1 to a device
*) If this device did not receive both a 0 and 1 in let's say the past 5 minutes, the set-up will be shut down automatically (as long as the program is running, the device will receive 0 and 1, if the program crashes it will receive either only 1 or either only 0)
Do you think something like this is possible?
Best regards
Elly
10-24-2011 07:59 AM
If it is a dangerous situation I would use an FPGA with a Watchdog Timer to shut down on emergencies. You could use an external Watchdog circuit to shutdown if communications to the PC is lost. A 555 timer setup to run as a watchdog timer that controls a relay to shut off the fill would work.
10-24-2011 08:03 AM
Best regards
Elly
Sure that's possible and could be a quick fix. But, be sure to implement error handling if you get some time; we all underestimate how important it is when building an application. Or, a watchdog as suggested above.
10-24-2011 10:24 AM
Thank you for your quick reply.
I am not familiar with FPGA, watchdog timers and 555 timer set-up. Can you tell me where to find more information about this.
Best regards
Elly
10-24-2011 10:34 AM
Search Google for Watchdog Timers. They have USB, serial, and other options. Some will plug into your PC, others are external. You would just ping the device. If the device doesn't see the ping, then it opens or closes a relay. You have a few options such as feeding your power supply for your control through it. When the relay opens, your supply is lost and your valves close (assuming they are normally open).
10-24-2011 04:45 PM
As some others have advised, it is never a good idea to rely on software running on a non-real-time OS for safety.
Just put a float switch on your vessel, with the output wired to a relay or other means of stopping the fill. You can monitor the status of the safety switch from LV if you wish: This is the opposite of relying on software for the safety.
Lynn
10-27-2011 02:13 AM
A watchdog timer seems to be a suitable solution for my problem
I am using the following NI-cards
NI 9203 (to read pressures --> linked to reactor levels)
NI 9265 (to control the pump)
NI 9481 (to control valves of the reactors )
NI 9421 (to read the level of my liquid storage vessel)
In case Labview crashes at least the pump needs to be switched off.
Do I understand it correctly if
i) I need to buy a "watchdogtimer" (= piece of hardware)
ii) I need to reset the counter of the watchdog timer every x seconds (this I need to program in Labview)
iii) If my program crashes than the watch dog timer will become 0. A signal needs to be send to the pump to switch it off.
Does anybody has an idea where to buy a watchdog timer?
10-27-2011 12:24 PM
Many programmable logic controllers (PLC) can perform watchdog functions and are designed to be robust in industrial environments. Many automation companies and soem electronics or industrial distributors sell them.
Your questions about understanding are all correct.
If you are unfamiliar with these types of equipment, you might be better off bringing in a expert to advise you so that you do not overlook some important aspect of making your system safe.
Lynn
