Safe-ishly "Upgrade" flattened cluster
@drjdpowell wrote:
@avogadro5 wrote:
@drjdpowell wrote:
Have you considered just saving as JSON, rather than flattened clusters?
With the built-in JSON unflatten, I have been unable to unflatten into a cluster with different elements than the original cluster that was flattened, even when it should be "obvious" how to adapt such as adding a new uniquely named attribute.
I'm trying to avoid using a serializer addon that includes the code to interpret each potential type as I have learned not to trust that kind of addon very much.
Well, the limited use of the inbuilt JSON primitives are why other JSON libraries exist.  I wrote JSONtext myself, and from that experience I can see that making the subVI you want is certainly possible, though you didn't convince me that the JKI one doesn't already work.
The JKI one doesn't support collections. It also doesn't strictly match the input default's datatype.
Message 11 of 14
(2,463 Views)
Comments on your example:
I'm trying to guarantee the type of a variable doesn't change at runtime so one check I've added is to only accept value updates via the "data string" which asserts a compatible memory structure
Are you not using strict-typed data in your program?  Libraries like JSONtext assume you are converting to some strict-typed structure like a Cluster, with any Variant being an intermediate step in conversion.  Strict-type data can't change at runtime, so I don't understand what you are doing here.
would like an error/warning or another output letting me know some JSON was not understood
This has been requested before, so I might add a "Missing Items" output in JSONtext.
Though other ways of doing data-type changes from old versions are:
  • include a "Rev" or "Format Revision" element in the JSON that you read first, just a number that tells you what version of the data structure is saved, thus allowing mutation code
  • Have code to test the JSON, like checking if "a" or "q" exists, thus knowing what version you are handling an triggering mutation code
Having a Dialog to ask the User is a much weaker design than including code that automatically handles older formats of the data.
For example, 'in Revisions earlier than 2 "q" was named "a".'
Or even, 'in Rev earlier than 2, if "High Power" = True, then set "Power Level (%)" = 90'
Message 12 of 14
(2,442 Views)
@avogadro5 wrote:
@Yamaeda wrote:
It works well with to/from flattened variants, just add some filler 0x00's to the flattened string so there's some data to convert from.
If I'm understanding this correctly is it suggesting that I would have to inspect the 2 datatypes and insert padding string(s) to make the old string compatible with the new one?
Kind of. If the new type has more data it'll create an error if there isn't enough to work with. If you test with the opposite, a smaller cluster, it'll take as much data as it needs and ignore the rest.
With that in mind, if you just add a bunch of nulls the new/added elements should get default values.
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 14
(2,420 Views)
Accepted by topic author avogadro5
There appears to be no existing code with the features I'm looking for. Thanks for the input that what I want to do is wrong.
Message 14 of 14
(2,366 Views)
