SYNCHRONIZE DAQ ANALOG OUTPUT CHANNELS
How can I synchronize bipolar digital data out of a DAQ chan. (DAC0OUT) with
a clock signal (same bipolar params.) out of the other DAQ chan. (DAC1OUT)?
I'm using a DAQCard 1200 to capture Teletype (TTY) like data at 4800 bps
and streaming it to the hard drive. Once the data is canned on the hard
drive, the intent is to send the data stream out one of the analog DAQ channels,
however, it needs to be accompanied and in sync with a 4800bps clock. Parameter
requirements are +/- 5VDC, therefore I'm restricted to the analog channels.
L. Jessup
Message 1 of 1
(2,341 Views)
