STOP Data taking ........are you sure ???
I want the user to stop taking data but I also want them to have a choice of yes or no or cancel in case they prematurely pressed the stop button without thinking.
These are students using the Vi.
I tried doing this using case structures which works fine if the user says OK but if the user cancels then the dialog message constantly pops up.
Message 1 of 8
(3,200 Views)
re:???
where is the rest of this thread?
There are a ton of solutions to this problem, but it would help if we knew a bit more about the current program implementation.
For instance, is the stop a latched boolean?  Is the whole program in one spreadout while loop, state machine implementation?  Are you using an event structure to 'read' the stop? Are you using a standard dialog box? ETC.
Paul
Message 2 of 8
(3,190 Views)
YES
All within the same while loop
None in the Vi
I was trying to do it with a case structure but anything that works is fine
I was using a dialog box but when I choose cancel the box keeps popping up.
Message 3 of 8
(3,178 Views)
If you attach a simplified version of your code, we could spot the problem and help you fix it.  It the message keeps popping up, your loop is not terminating when it should.  Perhaps a boolean switch control not set to a latch type.  Perhaps the stop loop condition not quite correct.....
- tbob
Inventor of the WORM Global
Message 4 of 8
(3,176 Views)
This is basically what I want to do Smiley Happy
If I press cancel the message doesn't go away.
Any method that would allow me to choose yes or no is fine.  Doesn't have to be particularily the way I started to do it.
Message Edited by ugman on 05-30-2007 11:52 AM
Message 5 of 8
(3,170 Views)
I will refrain from critic on the code, because I think you intoned this is just a sample that illustrates the problem.  To make this example work, then create a local variable, change it to write and stick it inside the case statement with the dialog, wire it to the output of the dialog or drop a false constant in and wire that.
Problem solved.
Paul
Message 6 of 8
(3,152 Views)
Your loop should have a timer inside so that the code doesn't use 100% CPU time.  Also, you could put a loop around the whole code, then when you run the vi, it won't start until you click the front panel switch.  Also, you can skip the inverter that feeds your case structure by just exchanging the True/False cases.  See the attached code.
This would be better done if you would use an event structure.  Capture the switch value change event.  Put the message box in the event case.  If the user presses cancel, you can just discard the value change.  No need to write back to a local variable.  Try it.
- tbob
Message 7 of 8
(3,143 Views)
Thank you all !!!
I will also try using event structures.  I have never used them (newbie) so I have to dig out some labview nooks.Smiley Happy
Message 8 of 8
(3,139 Views)
