I'm using Labview as a test platform for communication interfaces. I would like to perform some traces on TCP/IP. Which VI should I use ? How do I have to configure it ?
I would like to decode ethernet frames betwenn two equipements. So, I'm a quite newbie with Labview and it's seems to be not so easy to use dll's in Labview.
I look for a tool (vi using a dll?) that give me all ethernet frames transmitted between two equipements.
Hi, I recently work on it. Even if I have some difficult I wrote a dll using Libpcap ( see winpcap.polito.it but it can't be used by LV6 ) and the associate vi. These run with NT4. My problems now are to decode these ethernet frames to something usefull like in ethereal or somethink else. Give your e-mail I'll send you all I do but I can't say when.
Eric
"pfg158" a ecrit dans le message de news: 50650000000500000020750000-1019262487000@exchange.ni.com... > I would like to decode ethernet frames betwenn two equipements. > So, I'm a quite newbie with Labview and it's seems to be not so easy > to use dll's in Labview. > > I look for a tool (vi using a dll?) that give me all ethernet frames > transmitted between two equipements.
