SPI read sensor VN-100
I'm trying to communicate with VN-100 IMU sensor. How can I convert the read frame to three floats?
In a normal programming lanague I'd make a record of three floats and write to the adress of each element in the record. Is  it possible to do this in LabView?
(1,161 Views)
Accepted by topic author aan928
what values you get from Read frame,
Do you want to extract the output of read values into three values?
If  i am right you will get an array of 12 Indexs and Each 4 Indexes represent  value of (Yaw, Pitch, Roll).
To Make it work
Use array subset and Extract the required Number of Indexes and convert them into Respective value.
For Detailed Answer Provide the read values.
Palanivel Thiruvenkadam,
CLA|| CTD
(1,110 Views)
I believe what you are after is the Type Cast Function
-DR2
(1,100 Views)
