SMTP send email to multiple recipients
I am trying to send an email to multiple recipients use the .NET Constructor. It works great when sending to one email but how do I format the string to send to multiple recipients?
Can someone help on how the format needs to look like?
(2,837 Views)
I'm still working on trying to get the appropriate .NET API available to check, but based on the documentation here: MailMessage-To (.NET Framework), you should be able to get a MailAddressCollection and then modify that with additional addresses to send to multiple addresses at once.
This thread might also be helpful: https://forums.ni.com/t5/LabVIEW/Send-email-on-labview-using-the-Gmail-Server-TLS/td-p/474461/page/9 (see message 84 onwards).
GCentral
(2,792 Views)
Accepted by topic author GaryGC
The solution is to change the property to string. Now I can send to multiple by adding the comma between the emails.
(2,773 Views)
