03-06-2020 12:48 AM
Hii,
I am opening html file in labview but facing some script error related issue, where properties and design of that html file is changing.
If same html file open in Internet explorer or chrome, (Web-page) it is opening as expected, but same html file when call in Labview using
"active-X" web browser, Web-page properties and design are changing.
I have tried all options related to active-x web browser properties
03-06-2020 12:55 AM
Can you share the code along with html file??
03-06-2020 01:13 AM
Hello karthik,
Thanks for your reply.
We can't share the HTML document due to some security issues. But i can share the Script error issues and I am attaching the same here. Please check and help me.
03-06-2020 11:03 AM - edited 03-06-2020 11:04 AM
Hi P Vidya sankar,
From the screenshots it looks like the browser that the version of Internet Explorer loaded by the IWebBrowser2 control does not support the method addEventListener or the method getElementsByClassName.
Using the tool caniuse.com we can see that addEventListener and getElementsByClassName are supported in Internet Explorer 9 or greater.
The third party blog Web Browser Control & Specifying the IE Version describes ways to configure a newer version of Internet Explorer when using the IWebBrowser2 control. One approach it describes is adding the following tag to the head of your html document:
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
Which looks like the following in a full html document (from the third party blog):
<!DOCTYPE html>
<html>
<head>
... other headers
</head>
<body>
... content
</body>
</html>
With the header added you should also verify that you have a recent version of Internet Explorer available on your system. The third party blog goes into more details.
03-07-2020 04:14 AM
Hello MIlan,
Thanks for your help.
I changed the IE version in Code. Now there is no issues.
11-20-2020 05:06 AM - edited 11-20-2020 05:30 AM
Hi P Vidya sankar,
I am also facing the same problem.
whereas i have no access to the html code. Whenever i call the url i get the script error.
Could you please tell me the procedure to change the IE version from the labview 2019.
Thanks and regards
Avinash
