03-17-2011 10:36 AM
Hello Keith,
The problem seems to be that you do not have a "HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW\CurrentVersion" registry folder. When I install LabVIEW 8.6 or 2009 on a test machine, it creates that folder for me. We need to figure out why that folder did not get created. How did you install LabVIEW 8.6 and 2009? Maybe from Platform DVDs? Or do you have some other type of media? Did you install as an administrator or a standard user?
If you're comfortable working in the Windows registry, a workaround to the problem is to create the CurrentVersion folder underneath the LabVIEW folder. In your 9.0 folder, note the contents of the Path, Version, and VersionString keys. Create identical keys in the CurrentVersion folder and the installer should behave normally.
Grant M.
Senior Software Engineer | National Instruments
03-17-2011 02:37 PM
Hi Grant,
I'm not sure what you are asking me to do..you said note the values of....?
Can you send a screen shot of what I need to do?
I installed from DVD's from the factory.
03-17-2011 02:45 PM
Hi Grant,
Never mind. Once I reread it, it made sense, and I was able to add the registry keys and it installed successfully.
Thank you very much!! Case closed 🙂
(assuming it works once installed )
03-17-2011 02:54 PM
Hi Grant,
Is there a document that shows which commands and/or functions are supported? For example, I assume all of the graphing must be done using Labview graphs and not the "plot" or "subplot" functions in Scilab, correct?
Keith
07-13-2011 09:18 AM
I have Labview 2010 Base version. Can I use the Gateway with this version ?
best greetings
Michael
07-14-2011 02:12 PM
07-23-2011 10:41 AM
hello buddy ,,i really need some help ,how can i start to develope a programming of PID controller for second order optimization where PID is the feedback. I already used all the boxes ; Step function(source),Summation,CLR,PID,MUX,CSCOPE,CLOCK_c (source). But i had better know how to write the coding that thorughly related to the function.please guide me buddy
07-23-2011 10:53 AM
hello buddy
I really need some help ,,,how can I start to develop a particular coding of PID controller for second order optimization where the PID is the feedback? I already implemented all the boxes ; STEP FUNCTION (source),SUMMATION,PID,CLR,MUX,CLOCK_c and CSCOPE and through the combination of all these boxes ,it works well but I had better know how to develop the coding and type it in the Scilab Console. Could you guide me? please buddy
The PID used to optimize parameters in order to obtain saturation values of P,I and D that would be stored then.
07-23-2011 11:10 AM - edited 07-23-2011 11:17 AM
@Pahang wrote:
hello buddy
I don't think I am your buddy yet, but ...
What are "boxes"? (hardware? Software?)
@Pahang wrote:
... it works well ...
Why do you need help if it "works well"?
Attach your code so we can better see what you are doing and what the remaining problems are.
(This thread is about the scilab gateway itself. You seem to have a (scilab) programming question. That should be in a new thread.)
07-23-2011 11:40 AM
owh sory man ....erm, i mean it stands for hardware ,i got all the boxes from Pallete browser ,,, so i just need to develop the coding for that function ... it's a case study
this is what i got ffrom youtube:
http://www.youtube.com/watch?v=CC6yONnLSlY
i need to develope the whole coding for the system
im sory brother ,i have tried to find out a lot of materials and im new to use this software ,,may be u can guide me for this
