Running my program, it shows a sub vi on screen all the time
Well guys, my program has a lot of sub vi's
but only when I try execute one thing in my program
all the time the especific sub vi appears in the screen
and the others don't do it...
I never see this happen, so why it's appearing when I click next?
How can I fix it?
Thanks for the help
Message 1 of 9
(3,714 Views)
In vi properties you wouldve chosen "open when called".
Message 2 of 9
(3,708 Views)
Well, this option isn't marked
I only selected 2 options:
- Auto handle menus at launch
- Auto Debugging
Is something like that: When I click next this sub vi open make the calc and then closed, maybe this sub vi is too big or slow?
Message 3 of 9
(3,702 Views)
Accepted by topic author EduU
In vi properties-->windows appearence-->Customize
Click "close afterwards if originally closed" also if you need that to be opened first.
Message 4 of 9
(3,701 Views)
It is probably due to the properties of that sub-vi.
Open the sub-vi in question.  In the File menu, select VI Properties.   I think it's under execution.
You'll see a bunch of checkboxes.  See if there is a checkmark next to Open Front Panel when called (or something similar - I don't have LV to check accuracy).  Also check the other settings, as it may affect how it appears (on top, etc).
EDIT:  Thanks Muks..  I took me a while to post, because I couldn't fully remember all the items in the Properties window.  😉 LOL!  I wan't so far off after all...  LOL!
Message Edited by Ray.R on 11-03-2009 07:54 AM
Message 5 of 9
(3,700 Views)
Which VI's vi property is it? May be you are checking the main vi's vi properties Check in sub VIs properties.
Or may be you could post your VI here?
Message Edited by Vsh on 11-03-2009 07:07 AM
Message 6 of 9
(3,688 Views)
Muks already got it!
Now is fine!
Message Edited by EduU on 11-03-2009 07:11 AM
Message 7 of 9
(3,684 Views)
:smileywink: LOL!  I wan't so far off after all...  LOL!
 :smileyvery-happy:
For once ray.......... :smileyvery-happy:
Message 8 of 9
(3,671 Views)
LOL!  I simply hope that it's not a sign of old age...  😄
Message 9 of 9
(3,668 Views)
