🙂 The tutorial seems to be perfect, I'll try it out tomorrow.
Labview crashing happens mostly during the development phase. I have correleted the crashes to two features of Labview. First Labview crash sometimes when one edits the palette sets. Second Labview doesn't handle neatly the new lvlib libraries, especially when one library is nested inside another. Last time I got Labview to crash when I had a A inside which was library B inside which was library C. Library B contained a typedef which VIs in library C used. Then I made a copy of library B using save as command. I assumed that library C also gets copied. Well saving a copy of library B screwed up everything in the copy of library C and then Labview crashed.
If one makes a source distribution of such a nested library structure (C inside B inside A) labview also screws things up, I doesn't crash but the source distribution is not what you would expect.
Tomi Maila
