Running Labview in the embedded board - MinnowBoard or raspberry pi 2
It is possible to running the executable's LabView in the embedded board?
like a raspberry pi 2, minnowBoard, BeableBone?
Message 1 of 19
(5,586 Views)
Hi Eduardo,
I don't think so: There is LabVIEW for Linux, but it is limited to Intel processors. No luck with your embedded boards…
Maybe someone, who visited NIWeek, has updated information?
Message 2 of 19
(5,576 Views)
There is a group working on making a LabVIEW compiler for Raspberry Pi.  I think it is due out later this year.  I'm not finding the email talking about it right now, but I'll keep my eyes open for it.
GCentral
Message 3 of 19
(5,562 Views)
Accepted by topic author Eduardops23
That's the one - http://www.tsxperts.com/labviewforraspberrypi/
Looks really cool, but still some time away.
Edit - it should be pointed out that they do already have the Arduino version out. I haven't had a chance to use it, but obviously the Pi is a more promising target due to its advantages.
http://www.tsxperts.com/arduino-compatible-compiler-for-labview/
___________________
Try to take over the world!
Message 4 of 19
(5,552 Views)
 Thanks so much for your reply.
 let's wait until December to see if it's good.
Message 5 of 19
(5,539 Views)
tst escreveu:
The Intel NUC works an application Labview???
Message 6 of 19
(5,472 Views)
The NUC is an ordinary x86 PC, albeit in a small form factor. Install Windows or Linux on it and it should run LV without issue.
Getting back to the Pi, a related question I've had kicking around is whether there's any prospect of getting NI-VISA, and specifically NI-VISA Server for the Pi or similar hardware? It would make for a cheap and easy way of remotely accessing instruments; put $35 worth of Pi next to the instrument(s), plug in an Ethernet cable and (for instance) a USB to GPIB converter, and then open up a remote VISA session from the actual measurement computer running LabView. I can do that now with a cheap x86 machine, but a Pi is an order of magnitude cheaper...
Message 7 of 19
(5,448 Views)
My application is a Farm Automation.
I want to use the Intel NUC or Pi 2 for controller all sensors and motors. I need to a report every day from E-mail.
Message 8 of 19
(5,431 Views)
MinnowBoard is intel based. It should work.
Message 9 of 19
(5,390 Views)
igagne escreveu:
I live in Brazil and it is hard to find this board. Please could test for me?
Message 10 of 19
(5,374 Views)
