If you install the drivers from the 3. part driver database from NI.com you will get the dll files into the labview folder. you still need a few dll files from the Epos contol software, at least i did.
I use the 32bit dll since i use the 32bit LV, even thoug its on 64bit system.
you can change the linked dll when you open each of the comands functions and click on the " call liberay function node "
