Run startup.rtexe in linux from terminal
Experimenting - I changed the rtexe to run at start-up.  Tehn rebooted, and stopped the program.
Then ran the script file to launch the rtexe again - this time the VI appeared on the gui, but then quit.
"Startup Application:/home/lvuser/natinst/bin/startup.rtexe
Welcome to LabVIEW 19.0.1f1
LabVIEW caught fatal signal
19.0.1f1 - Recerived SIGSEGV
Reason: Address not mapped to object
Attempt to reference address: 0x0x7f07c8005104
./lvrt-manuallaunch: line 6: 11673 Segmentation Fault    /usr/local/natinst/etc/init.d/lvrt-wrapper $STARTUP_PARAM $PID_LVRT_WRAPPER SUI_ENABLED"
When I don't set it to Run as Startup and run the bash file to launch lvrt-wrapper - it simply stops at
"Welcome to LabVIEW Real-Time 19.0.1f1"
And doesnt open the VI front panel....odd.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 11 of 13
(2,270 Views)
OOPS - removed the Invoke FP.Open
No more Segment faults.
The RTEXE has to be set to Run as Startup for the lvrt-wrapper call to launch the VI - which is kind of annoying.  I'll have to see if I can avoid having to use that setting.
Message 12 of 13
(2,257 Views)
I'm told it can't be avoided using Run as Start-up.
I will create some start-up script that will run before the LVRT start-up process and set a flag in an INI file for RUN = FALSE that my code will use.  It will shut itself down if not started by the program I want to use to launch it on event detection.
Then my xinetd port monitor will be able to leverage the script I have created to run the LV RTEXE, by first setting the RUN = TRUE.
Message 13 of 13
(2,230 Views)
