Run 8.6 executables on Windows 7?
No I did not...thanks for that one!!!
Message 11 of 15
(1,367 Views)
@dan_u wrote:
If you use the COM port, did you install the VISA runtime on the target machine? Just the LV Run-time is not sufficient when using devices that need drivers.
Been there, done that! Several times even ... ^^
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 15
(1,355 Views)
/Y
Me too... can be frustrating when this happens on site with the client...
Message 13 of 15
(1,351 Views)
So just to clarify -
  1. Each version has its own RTE. The RTE from one version CANNOT run VIs or EXEs saved with another version (with the exception of some minor releases such as 8.5 and 8.5.1).
  2. You CAN run 8.6 EXEs on Windows 7. The big issues that usually crop up are heightened security which sometimes breaks old programs and drivers, which are not always compatible.
  3. In the drivers department, serial device drivers (particularly USB to serial converters) are notorious for having a potential for problems under 7, so you'd better test them well or make sure you get a good kind.
___________________
Try to take over the world!
Message 14 of 15
(1,345 Views)
@Yamaeda wrote:
I was trying to find a link but couldn't find any right now. If memory serves it's a deduction from the 2010 install only installing 8.6 runtime.
/Y
The reason why this happens is that some support software/tools were built under that version of LabVIEW, so it requires that version of the RunTime.
Message 15 of 15
(1,326 Views)
