Routine structure?
Dear Sir
            I would like to know how difference between series and parallel procedure routine, please see the attached file for your reference.
            Please let’s me know advantage/disadvantage between them.
(543 Views)
Highlighted
It's all about Data Flow.  In a Serial arrangement, Routine 2 cannot begin to run until Routine 1 finishes (and sends its data to Routine 2), and Routine 3 cannot begin to run until Routine 2 finishes.  Let's say Routine 1 takes 1 second, Routine 2 takes 2 seconds, and Routine 3 takes 3 seconds -- the Serial sequence takes 6 seconds.
When routines run in Parallel, the CPU time is "shared" between them.  There is no "predictability" to the order that code is executed -- in particular, you cannot predict which one finishes first, second or third.  If Routine 1 takes 1 second, Routine 2 takes 2, and Routine 3 takes 3, doing all three in parallel will take a minimum of 3 seconds (and, in many cases if the routines are not "compute-bound", they might all finish in 3 seconds, too, as Routine 3 can run while Routine 1 is "idle" (say, waiting for a File to open).  The three routines share the CPU, with cycles allocated according to some internal scheduling algorithm.
This makes LabVIEW an inherently parallel programming language.
(526 Views)
Don't forgot with parallel processes you can use the snazy phrase "my code is optimized for multi-core computers"
(522 Views)
