Rotate object vi from tip/end and not from centre
Hi
Just like the Clock needle is pivoted from the end, one of my robot needs a deflection in 3D picture modeling. Rotation VI is changing angle but w.r.to centre and not the end/tip.
Can anyone suggest me the solutio ASAP.
(2,728 Views)
Hi virtualworld,
If you use 'Set Rotation.vi' you can input a cluster of arrays that point to the coordinates of the axis that you wish your object to rotate about.
You will just have to tinker with it until the coordinates match to the end of your object.
Hope this helps,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(2,719 Views)
Thanks Jon
I tried so many combinations....however getting the same results. Can you try out for me.
Please see attached vi.
Your first reply was quick I hope this time too. Smiley Tongue
(2,700 Views)
