Rotate a parable in XY Graph
Hello!I have a parable on an xy axis, how can I make it rotate around the origin of the coordinate system or around the tip?
How do I do the same thing with moving a sphere on the parabola, from one end to the other, and how can I change the speed of movement?
(2,658 Views)
Hi Whifitws,
Well, in your VI there is no plot when I run it - you forgot to set some useful default values…
On the rotation: as a student you should have heard about complex numbers before and how they are visualized on a XY plane. You should also know about conversion between Re/Im and r/theta representation: convert your XY coordinates to complex numbers, then change their representation to r/theta, then simply apply basic complex math by changing theta to "rotate" around a certain point in your XY plane…
(LabVIEW perfectly handles complex numbers, even in XY graphs, and supports you by functions dedicated to complex numbers!)
(2,645 Views)
Or just multiply with a complex number (r=scale, theta=angle). Also make sure to not autoscale the axes and size the xy graph so the x and y scales have the same range and length (i.e. square gridpoints) to avoid distortions.
(To rotate about an arbitrary point, flank the code with an subtract/add of the center RE/IM complex point. Not shown)
(2,621 Views)
(2,613 Views)
