Rotate PNG image with user defined angle
I tried rotating PNG image with attached code in LabVIEW 2016 version.
I took help from one of NI thread:
Rotating Graphics (Pixmaps) in LabVIEW
http://www.ni.com/example/26943/en/
Now, I am able to rotate input image with user defined angle (in degrees).
You can take any PNG image with transparent background as a input file.
The image is with transparent background.
I want that image with transparent background to be shown in picture indicator.
It is currently showing white background.
Can somebody please help, how to achieve this.
(2,450 Views)
1# use a mask to render transparency in a Labview Picture Plot e.g.
National Instruments\LabVIEW 2017\examples\Graphics and Sound\2D Picture Control\Using Mask with Picture.vi
2# use Darin K.'s .vis to save this mask layer as an alpha layer  32 bit .png
"https://forums.ni.com/t5/LabVIEW/Create-transparent-PNG-using-quot-Write-PNG-File-vi-quot/td-p/11397..."
(2,421 Views)
a bit more elaborated ...
(2,394 Views)
