Rockwell Point I/O with labview? (Ethernet IP)
Would it be possible to read out a Rockwell point I/O module? It is normally connected to a Compact IO PLC.
We want to make a PC based test/control. It has some simmple digital outs and analog inputs, nothing special.
I've been looking at the Ethernet IP module from NI, but I don't know if its suited for this.
Felix
(3,225 Views)
hi Felix,
In case you Rockwell I/O device can be a master, this library should allow you to communicate with it from Labview. It alows a LabVIEW target to be a "slave" on any EtherNet/IP system:
https://decibel.ni.com/content/docs/DOC-4065
Jos
(3,169 Views)
