10-05-2020 02:46 AM
Einen schönen Tag an Alle,
ich möchte/muss die Ring-Beschriftung dynamisch ändern und habe dies mit den Eigenschaftsknoten versucht.
Obwohl z.B. der Untertitel eines Rings so geändert werden kann, bleibt die Beschriftung davon irgendwie unbeeindruckt.
Den Ring einzeln (und nicht in einem Cluster) zu setzen und/oder nicht mit Schieberegistern zu arbeiten ändern hier leider nichts.
Kann mir jemand von Euch Experten auf die Sprünge helfen?
Schöne Grüße
Ralf
Solved! Go to Solution.
10-05-2020 02:56 AM - edited 10-05-2020 03:01 AM
Hi Ralf "knuckle of pork",
as this is an English forum you should write your messages in English.
When you are more comfortable using German you could post in the German www.LabVIEWForum.de!
To answer your question:
10-05-2020 04:14 AM
Bugger! My bad.
I don't know why NI has put me into this forum, but okay.
If I understand you right then you can't change a Ring-label using property nodes (although this is a property node option), but the captions.
Thanks!
10-05-2020 04:31 AM
@Eisbein wrote:
Bugger! My bad.
You can't change any label if the VI is running, not just rings but not for any control or indicator.
You can use a property node to change a label if the VI is not running (get the reference through VI Server). That is why the label.text property is read\write.
Captions can be changed when the control\indicator is running. Labels are used on the diagram, and changing them would change the diagram, which can't be done while the VI is running (except breakpoints).
10-05-2020 04:41 AM
Hi Eisbein,
Because you choose to post in the NI LabVIEW forum.
The German www.labviewforum.de operates independently from NI…
10-05-2020 04:54 AM
@GerdW wrote:
Hi Eisbein,
Alternatively, Google translate does an OK job nowadays.
10-06-2020 03:20 PM - edited 10-06-2020 03:59 PM
