Rewrite the tdms file keeping some of the data values.
I am writing a code in which data values  saved in the TDMS file in two ways. 1. From DAQ  2. Manual input. Both of this inputs should be in parallel.
Whenever I give manual input, it should overwrite the previous values and to be saved in the previous location. Whereas data from the DAQ should not be  altered.
These are the difficulties I am facing in this code
1. If I use, TDMS open (existing)  to write the data, It will adds the data to the previous data. Whereas I nead it to overwrite existing.
2. If I use create and replace option, I loose the data from the DAQ.
Please suggest me better way to do this function.
Thank you
Shrinivas
(3,559 Views)
My colleague who is learning LabVIEW asked me about this yesterday. Here are the options I gave to her in order of my preference:
1) I would personally not want to modify an existing file with raw data in - I would just log the raw/DAQ data into its own TDMS file and if you are producing any additional files with manually input data then combine the DAQ data and the processed data into a new TDMS file.
2) If you definitely want to update the existing file, you'll need to read out the raw data channel from the file, write that data to a new file with your modified data. You can then close the original file and rename it to overwrite the original, if you want.
I told her that TDMS files are really supposed to be for your raw measurement data so I couldn't really see why you would modify that data (it's like fudging your results in science!) - for presentation/reporting I would take that raw data and put it into a new file.
(blog)
(3,540 Views)
Hi Shrinivas,
If the raw data is not DAQmx raw data, TDMS Set Next Write Position Function is provided to overwrite the existing data in a .tdms file. The function is located at Advanced TDMS Pallette. But TDMS component does not support overwriting DAQmx raw data.
Jie Zheng | TDMS | LabVIEW R&D
(3,493 Views)
You can delete data in a TDMS file using the function File IO > TDMS Streaming > Advanced TDMS > TDMS Delete Data.
You must to provide the absolute path (including the .tdms extension), group name, and channel(s) name(s) you want to delete.
NI Distributor Ecuador
CLD + CPI
(3,127 Views)
