Reverse engineering a VI
   Please check out the attached VI. I've inherited code from a previous engineer and I'm trying to wrap my head around how this particular VI works. I appreciate it!
Jay
Message 1 of 13
(3,907 Views)
You did not attach your typedefs, but you have a cluster of two enums, each with four choices. Two bits are sufficient to describe four states, so you create an output array with four bits to fully describe the state of the two enums.
You can look at the help for any of the primitives. Let us know if anything is not clear..
Message 2 of 13
(3,831 Views)
Without the VIT Config cluster i can't tell you exactly what it does, but assuming that Voltage is in volts and Current is in amperes then what you are doing here is you convert an 8 bit number to boolean array, negate it and then take the first two values of boolean array.
So it basically ignores values less than 64 (so 64V or 64A) and then writes two most significant digits negated to DAQ.
EDIT: It'd also help to know what this controls, because right now i can't really imagine what you would control like this.
Message 3 of 13
(3,790 Views)
   Thanks for the replies! I've attached the .ctl files that go with this.
So this VI sets the voltage and current range to be sensed and measured. Rather than having enum drop-down windows to select the ranges, I'm attempting to allow the user to just type in the what voltage and current the device under test requires, then the ranges automatically get set without needing to be selected.
I'm not sure what the best approach to this would be. Maybe tie the enums into a case structure? Although I believe the VIT may need the binary settings to be written to it all at once.
Any suggestions would be appreciated!
Jay
Message 4 of 13
(3,773 Views)
What I have done for this is use the Threshold 1D Array with the desired range and an array of available ranges.  You can use Round To +Infinity To then use Index Array on the available ranges to get the actual range to use.
Message 5 of 13
(3,760 Views)
How would I interface this with the needed binary output to properly communicate what range to set the VIT?
Jay
Message 6 of 13
(3,747 Views)
Accepted by JayWW
Instead of indexing the original array, index another lookup table.
Message 7 of 13
(3,740 Views)
What kind of array is the circled icon? It doesn't look familiar.
Jay
Message 8 of 13
(3,708 Views)
Hi Jay,
it's still an IndexArray function…
Message 9 of 13
(3,699 Views)
"index array". It looks different because the input is a 2D array, requiring two inputs for the index. The primitive automatically adapts to the wired input.
Message 10 of 13
(3,695 Views)
